👋🏻 Welcome To DIY Chatroom
DIY Forum
Home Improvement
Do It Yourself
Marketplace
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Forum Support
Latest Posts
Moved into a house 3 years ago. House is from 1954. This is near the wall up top near the ceiling above a built in that the previous owners DIYed. It's been sitting like this since I moved in? It's not the prettiest but it's blocked and you can’t really see it so it doesn’t bother me...4 replies 0 views
Hello. Opinions Please? I don't want anything that'll be detrimental! My 580K ruptured the main high pressure Hydraulic hose off of the front hydro pump,& Every drop in the tank dropped! I haven't needed to buy Hydraulic oil for a LONG TIME,,, & I now have sticker shock! I'm old,,, this will...6 replies 341 views
Before you hurry and tell me that I should be using pressure treated wood, please read this entirely, and carefully. I am a bee keeper, and I build "bee houses" which I mount on the exterior walls of my house. The boxes/houses I mount are approximately 3 feet long, 1 foot tall, and 1 foot wide...21 replies 131 views
Daughter is having current gas water heater with 4” galv ducting through roof (it is in basement of two story home with attic) replaced. How should the old vent and chase be decommissioned? Does installer typically do that? New one will go through side wall.1 reply 31 views
Hi, I built a new highly efficiency home base off the Passive House principle where we achieved a 0.47 ACH@50pa pre insulation and drywall. We have a small wood stove which we were having problems with cold downdraft in the chimney when not using it and I figures it issue was with our...22 replies 603 views
