Carpentry | Construction | Electrical | Flooring | HVAC | Landscaping | Painting | Plumbing | Roofing
DIY Blogs
Recent Entries
Best Entries
Best Blogs
Blog List
Search Blogs
Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Blogs
Reload this Page
Blog Entries
Register DIY Blogs FAQ Members List Search Today's Posts Mark Forums Read
Roof Shingles To Choose For Hotter Places
Posted 04-26-2012 at 09:34 AM by Bookerc
Tags roof shingles, roofing, roofing shingles
Roof shingles containing tar are a bad idea for hot regions. The heat from the sun will melt the tar out of the shingles and can be disastrous for the roofing. In fact if you carefully look at the building rules and codes you will note that all type of organic and tar roof shingles are barred for regions which have hot weather. These type of shingles also can't handle the wide variations of temperatures normally seen in deserts between day and night time temperature.
Choosing the right
Continue reading...
The health benefits of the simple act of properly caulking your shower panels.
Posted 11-27-2011 at 11:10 PM by WillK
Today as I was in the process of staging tools to drop into my crawlspace, I decided to take on a relatively small task of recaulking the tub. We've lived in the house a year, and the caulk job done was bad, but when you have fire hazards, leaky roofs and a 93 year old house sitting on cement blocks instead of a foundation, caulk seems low priority.
I've suspected the house of contributing to minor but frequent colds and coughs, but I've been focussed on bigger things like having ducts
Continue reading...
Click image for larger version
Name:	shower caulk after scrape 27NOV2011.jpg
ID:	10   Click image for larger version
Name:	nasty caulk 27NOV2011.jpg
ID:	11   Click image for larger version
Name:	cleaned up and recaulked 27NOV2011.jpg
Service upgrade and garage subpanel - updating the road to passing rough inspection
Posted 07-22-2011 at 09:55 AM by WillK
So as I write this, I have passed my rough inspection and am now waiting for the power company to make the incoming power connections for my upgraded service entrance at its new location. After they had reviewed the new location they indicated 10 business days, which would fall some time this week, unless they had to move it back due to emergency work such as storm damage, which there has been.
Since my last post, I came to the end of my contract period at my previous job, had to do
Continue reading...
Deck Staining & Wood Care
Posted 05-22-2011 at 07:32 AM by housepaintingny (House Painting & Staining)
Tags deck staining, pressure washing, siding stain
Deck refinishing and staining is a very popular service, but it is not done properly in most situations. The most important factor in deck staining is surface preparation. Great surface preparation is the KEY to outstanding results. Prep right, and the deck will turn out great. Rush through prep, skip a step (or two) and the deck won’t look nearly as good.
A major source of problems and complaints for all wood finishes is over-application of the coating. Many do-it-your self believe
Continue reading...
Service upgrade and move
Posted 05-13-2011 at 01:11 PM by WillK
First off, I'd like to start by thanking everyone that contributed in answering some of the many questions I've had in various threads I've started in the process of planning and doing this project. Anyone else considering similar work would likely learn a great deal reviewing these discussions:
http://www.diychatroom.com/f18/servi...-200-a-102301/
http://www.diychatroom.com/f18/servi...stions-102370/
http://www.diychatroom.com/f18/wirin...stions-102299/
Continue reading...
Name:	new service entrance.jpg
ID:	8   Click image for larger version
Name:	meter socket wired.jpg
vBulletin Message
Cancel Changes
Find Blog Entries
Blog Categories
  • Project Tracker Project Tracker
  • How To Guides How To Guides
  • Home Improvement Home Improvement
  • Product Reviews Product Reviews
  • Product News Product News
Options
View a Random Blog Entry
View RSS Feed
Global Tag Cloud
deck staining pressure washing roofing roofing shingles roof shingles siding stain
Search by Tag
Affiliate Disclosure - Contact Us - DIY Forum - DIY Articles - Privacy Statement - Terms of Service - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Our Network: Contractor Forum | Craft Forum | Woodworking Forum | Painting Forum | Drywall Forum | Electrician Forum | HVAC Forum | Plumbing Forum | Roofing Forum
