👋🏻 Welcome To DIY Chatroom
DIY Forum
Home Improvement
Do It Yourself
Marketplace
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Forum Support
Latest Posts
Daughter is having current gas water heater with 4” galv ducting through roof (it is in basement of two story home with attic) replaced. How should the old vent and chase be decommissioned? Does installer typically do that? New one will go through side wall.3 replies 73 views
Hey I need to wash a large double-glazed window but there's condensation between the two panes of glass I think. For a non-professional like myself do you guys know if I could solve the issue or is it a case of getting new window. Thanks for reading guys.6 replies 117 views
New garage build is it code in ontario for plastic device boxes?2 replies 43 views
A recent project I did has me seriously considering wago connectors for more electrical projects, but I want to check with experts in the field before I spend money on them, it was a light fixture I changed out, I took out the one over the bathroom sink and put in an led light, the wire nuts was...44 replies 2K views
