👋🏻 Welcome To DIY Chatroom
DIY Forum
Home Improvement
Do It Yourself
Marketplace
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Forum Support
Latest Posts
1: Can I install a 110V fan in an end table (similar to bathroom exhaust fan)? I'd use elec boxes just like doing regular elec work. It would plug into the wall via outlet like any other fixture... not sure how that part would be wired, so I assume this is a no. 2: Same as above but an outlet...20 replies 231 views
New garage build is it code in ontario for plastic device boxes?0 replies 0 views
Moved into a house 3 years ago. House is from 1954. This is near the wall up top near the ceiling above a built in that the previous owners DIYed. It's been sitting like this since I moved in? It's not the prettiest but it's blocked and you can’t really see it so it doesn’t bother me...6 replies 37 views
All right I've got two question. I'll break this up into three parts - overview, question 1, question 2. Overview My front porch is a brick box with about 1/4 inch of mortar / cement applied over the exterior face. Making you think the porch foundation were cement and not brick. Th house was...6 replies 111 views
Hello all, I currently have my main panel, in my garage. I have a sub panel running approximately 15 feet to my mancave with 100 amp service. I now need to run power to a shed. The run is approximately 85 feet. My issue is how to wire it. I'm trying to power a light right outside my mancave, and...8 replies 128 views
