👋🏻 Welcome To DIY Chatroom
DIY Forum
Home Improvement
Do It Yourself
Marketplace
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Forum Support
Latest Posts
Hello What would be the best pre-mixed drywall compound to use to skim coat a ceiling before repainting it? It's in a foyer, and surface is not that large.... Thanks17 replies 183 views
I am sure this has been covered 1000 times. But I was at a friend who is running two circuits in one raceway from his sub-panel (Sub-Panel is a workshop not connected to the house. Sub-Panel does have a ground going to a ground rod outside shop). Long story short- I disagree with the electrical...27 replies 295 views
I installed an interlock switch to run a 30 amp inlet for my generator on my last house pretty easily. It was straight forward as it was just a typical box with a main 200 amp breaker and I just put in a 30 amp to switch to when I was on generator power. I have ran into a problem with my new...2 replies 85 views
Hey, dudes! I’m in the process of remodeling my bathroom. In the below photograph are a bunch of water pipes. I’d really like to box these in before tiling. But for the life of me I can’t see how. They’re in the shower area and any design ideas I come up with can’t be properly waterproofed. I...0 replies 12 views
All right I've got two question. I'll break this up into three parts - overview, question 1, question 2. Overview My front porch is a brick box with about 1/4 inch of mortar / cement applied over the exterior face. Making you think the porch foundation were cement and not brick. Th house was...7 replies 136 views
