👋🏻 Welcome To DIY Chatroom
DIY Forum
Home Improvement
Do It Yourself
Marketplace
Vendor Member Section
Want to Grow Your Business? Learn more about becoming a Supporting or Premium Vendor
Forum Support
Latest Posts
Hey, dudes! I’m in the process of remodeling my bathroom. In the below photograph are a bunch of water pipes. I’d really like to box these in before tiling. But for the life of me I can’t see how. They’re in the shower area and any design ideas I come up with can’t be properly waterproofed. I...3 replies 48 views
So my measurements were clearly a little off when I drew up my tiling plan on SketchUp and after installing I am left with approximately a 1" gap at the threshold, which is significantly more than anticipated... What are my options to make this presentable? Thanks in advance!25 replies 267 views
I’d like some advice on my back lawn. There are some bare spots and lots of weeds. I used Scott’s Turf Builder Triple Action on it already. It killed some of the weeds. Do you think I can just aerate and overseed? If not, what would you recommend?4 replies 0 views
Daughter is having current gas water heater with 4” galv ducting through roof (it is in basement of two story home with attic) replaced. How should the old vent and chase be decommissioned? Does installer typically do that? New one will go through side wall.6 replies 89 views
To be code compliant in ontario for garage receptacles can they be on one circuit indoor receptacles and outdoor receptacles gfci one wall per circuit ? the only thing is if circuit protected by gfci breaker in panel if tripped you need access to garage to reset breaker2 replies 18 views
