Deck Staining & Wood Care - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Blogs > House Painting & Staining
Articles about house painting, deck staining - restoration, wood siding care, hiring a painting contractor for your house and pressure washing services.
Rate this Entry
Posted 05-22-2011 at 06:32 AM by housepaintingny
Updated 03-08-2015 at 06:47 AM by housepaintingny
The most important factor in deck staining is surface preparation. Great surface preparation is the KEY to outstanding results. Prep right, and the deck will turn out great. Rush through prep, skip a step (or two) and the deck won’t look nearly as good.
A major source of problems and complaints for all wood finishes is over-application of the coating. Many do-it-your self believe that when it comes to coating, more is better. This is simply not the case and is particularly a problem for decks. Most deck finishes are designed to penetrate the surface of the wood. Putting too much of these coatings on the wood leads to a buildup of material, forming a film which can ultimately peel or crack. For water repellent products, over-application can result in a surface which is overly waxy, sticky, or slick. Over-applied stains will often result in sticky surfaces, since the coating buildup interferes with their ability to dry properly.
Fact: All needs protection from the elements.
Why? The damaging effects of the weather on exposed, sun-protected wood begins immediately and last forever.
  • The day that you finish installing a deck or other exterior wood structure is the day trouble can start. Morning dew, rainwater, and melting snow are quickly absorbed by unprotected wood, causing it to soften and swell.
  • Direct exposure to the sun's heat causes drying, causing the wood to shrink.
  • Continuous cycles of wet and dry, swelling and shrinking cause wood to warp, split, crack and check-all of which leads to premature wood degradation.
  • Surface graying is caused by exposure to the sun's UV rays on unprotected wood.
  • Consistent moisture creates conditions for the growth of mildew, algae, mold, and other fungal organisms that feed on wood. spreading across and staining the surface.
  • Termites and other wood boring insects also use wood for a food source, causing rot and decay.
Weathered Wood:
If the wood on your deck is uncoated, it needs to be cleaned thorouly with a product specifically formulated to remove the aged top layer, which will rid the surface of its grayed appearance, ground in dirt, stains from food, fungus growth, including mildew, mold, and algae. I recommended using a per carbonated cleaner instead of a deck cleaner that contains bleach. Bleach has long term effects on wood and the glues that hold it together, just as bleach eats your jeans. After cleaning well follow up using a deck brightener. A brightener will remove tannin, stains, rust from nails, and will bring the decks appearance back to when it was new. I use a pressure washer to aid with my cleaning, but use low pressure 500-800psi.
If you have a previous failed coating on your deck you will have to strip it first using a stain stripper.
New Wood:
Just as in restoration of old wood, it is necessary to prepare the surface of the new wood before coating. Preparing the surface involves cleaning the new wood, in order to remove invisible surface barriers, such as excess wax, or mill glaze, a burnished surface often found on new cedar limber.
Preserve your woods beauty and structural integrity by following through with a regular maintenance program.Once your deck is installed and protected it should be cleaned once a year, inspected, and re-stained as needed. Daily exposure to UV rays willwear away the coatings surface layer, thus making it necessary to to re-apply periodically.
Splash water on your deck and notice if it is absorbed or beads up. If it is absorbed rapidly your deck is ready to stain. If it beads up you still have stain or contaminants on the surface.
Types of Deck Stain:
Transparent Deck Stainsare the lightest pigmented. These are also called wood toners and will enhance the woods natural beauty. They typically offer the least amount of UV protection from graying as the trans oxides are usually low. They offer the most natural look.
Semi-Transparent Deck Stains are higher in pigment and trans oxides. They still penetrate into the wood but have a higher ability to stop UV discoloration. Typically are "richer" in color then the Transparent Stains and accent the wood grain.
Solid "Opaque" Wood and Deck Stains are not transparent at all. They will mask or cover the wood similar to a paint but are thinner in consistency so they will penetrate into the wood cells. They offer the best UV protection from graying.
Views 6304 Comments 0 Email Blog Entry
« Prev     Main     Next »
Total Comments 0
Comments
