basement stairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Blogs > jfrance
Rate this Entry
basement stairs
Posted 05-05-2013 at 07:45 AM by jfrance
Temporary stairs put in basement in MA. They are 7" and building inspector approved because the unit was built in 1982 and said they met the code then. Does this sound right? If all other codes change and need to be updated when selling wouldn't this have to be also?
Posted in Uncategorized
Views 15074 Comments 3 Email Blog Entry
« Prev     Main     Next »
Total Comments 3
Comments
  1. Old Comment
    cocobolo's Avatar
    When you say 7", are you referring to the rise or the run?
    If it's rise, that's good, if it's the run...not so much.
    permalink
    Posted 05-31-2013 at 08:31 AM by cocobolo cocobolo is offline
  2. Old Comment
    Probably OP is referring to 'rise'; even 30 years ago, a 7" tread would almost certainly have been unacceptable.
    New fittings generally need to comply with modern standards, unless it was a repair, ie a straight swap with a new flight but fixed in the original opening.
    But if the inspector says it's OK, what's the problem?
    permalink
    Posted 06-29-2013 at 11:06 AM by tony.g tony.g is offline
  3. Old Comment
    Agreed; non-complying stairs often get approved if there's an existing opening that they needed to fit into. Sometimes new stairs also get passed, if there's an older stairway above or below that was to code originally, and which the new stairs need to parallel. And indeed, if the inspector says it's OK, then go with it.
    permalink
    Posted 06-30-2013 at 12:11 PM by CarpenterSFO CarpenterSFO is offline
