Basement Lights misbehaving... - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Blogs > Afrum
Rate this Entry
Posted 03-07-2015 at 08:38 AM by Afrum
So, my basement lights are going out intermittently...There's no fuse that's blowing, and then about 5 minutes later, they come back on for a random amount of time, then back out...I searched high and low throughout my house and couldn't determine a power source causing the issue. During Christmas time, lights plugged into an outlet above the basement stairs was preventing the lights from turning on at all, and now this on/off at random times issues....Any insight to a possible cause would be appreciated!!
Posted in Uncategorized
Views 3994 Comments 1 Email Blog Entry
« Prev     Main     Next »
Total Comments 1
Comments
  1. Old Comment
    A bad circuit breaker or a loose connection somewhere on the circuit are possible culprits. You need to open up all of the affected outlets and switches and check for loose or burned connections. Start with the outlets close to the electrical panel.
    permalink
    Posted 04-12-2015 at 01:55 PM by MrElectricianTV MrElectricianTV is offline
