4-STEP Installation Guide for PEX - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Blogs > gtglobe
Rate this Entry
Posted 05-12-2009 at 10:13 AM by gtglobe
Whether for potable water, radiant heating systems, or industrial use, installing GTPEX® is always fast and easy.
Here is our unique GTPEX® 4-Step Installation Guide:
1. CUT
Cut the GTPEX® pipe at a 90º angle using the appropriate PEX cutter, such as our GTCut tool.
2. INSERT
Insert the ring onto the pipe at about 1/8” from the end. Insert the fitting into the GTPEX® pipe until the pipe end tightly reaches the shoulder of the fitting.
3. CRIMP
Make sure the ring is still 1/8” from the end of the PEX pipe. Use the appropriate tool (such as GTCrimp) to crimp
the ring over the pipe until the tool is completely closed.
4. TEST
Test the crimp ring with the “Go-No-Go” tool to make sure the crimp pressure is satisfactory.
To do this, use the appropriate tool size and slide it directly
onto the crimp ring according to the crimp tool instructions. Do not slide the “Go-No-Go” tool on the PEX up to the ring.
If the crimp ring fits inside the end of the “GO” side, then your crimp passes the test and you may move to the next fitting.
If the crimp fits inside the end of the “NO GO” side of the tool, the crimp ring is over-crimped; remove the fitting and start
over with step 1. Before restarting, the crimp tool must be recalibrated according to the manufacturer’s instructions.
The 4-step installation is now complete.
If you need more information on the installation of GTPEX®, please contact us at 1-877-GTGLOBE.
About GTGlobe Industries
GTGlobe Industries manufactures high Quality PEX and Radiant PEX Tubing and Fittings.Reputed worldwide, the manufacturing of the GTGlobe Industries products are based on 30 years of knowledge and experience.
Certified and approved in over 20 countries, we are constantly looking to improve our production techniques and to develop new products. We are committed to commercializing the best range of dimensions, with pipes from 3/8” to 6” in diameter.
Posted in Uncategorized
Views 1225 Comments 0 Email Blog Entry
« Prev     Main     Next »
Total Comments 0
Comments
